1/20/2021 5:28 AM | |
Joined: 11/20/2018 Last visit: 10/6/2024 Posts: 20 Rating: (0) |
because we have licence for pcs78.2 we want install windows server 2012 on IPC847Eis it possible? ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 01/20/2021 10:19:11New subject after splitting |
1/22/2021 6:23 PM | |
Joined: 2/6/2015 Last visit: 10/2/2024 Posts: 80 Rating: (15) |
Hi MH-KARAMI, This IPC may come with the following pre-installed operating systems: - Windows 10 Enterprise 2016 LTSB, multi-language (64-bit) - Windows Server 2016 Standard Edition incl. 5 clients, multi-language (64-bit) as you could see at this FAQ: Simatic IPC847E now available for delivery https://support.industry.siemens.com/cs/ww/en/view/109763333 This PC has improvements at the hardware level so Windows 2012 Server are no longer available in the SIMATIC IPC847E. Best Regards, CGA81 |
