5/24/2023 5:21 PM | |
Posts: 3 Rating:
Hello, I've got the same problem. I solved it before, but now using the same steps I can not comunicate the plc with the HMI simulation. Any suggestions? ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 05/25/2023 07:59:53New subject after splitting |
5/25/2023 6:30 AM | |
Joined: 5/6/2022 Last visit: 4/16/2025 Posts: 585 Rating:
Hi AutoGen_1771241, Next I am going to share a FAQ that can help you, since it deals with the same problem that you are experiencing: Hope that helps. If not, answer us and we will look for other solutions. Best regards!
