1/27/2021 9:33 AM | |
Posts: 13 Rating:
I can not find Sinamics g120c gsd file. Type is 6SL3210-1pe16-1al1 ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 01/27/2021 10:10:02New subject after splitting |
1/27/2021 10:16 AM | |
Joined: 4/28/2015 Last visit: 10/22/2024 Posts: 1278 Rating:
Hi, you always need the correct GSD fitting to the firmware. You find the GSD downloads also on the SIOS pages for the firmware download. For example here for FW 4.7 SP10 HF6: https://support.industry.siemens.com/cs/de/de/view/109756820 Anyway the GSD files should already be available in your TIA Portal in the hardware catalogue under "other devices". Or you install Startdrive to your TIA as well and you can commission the drive completely in TIA, so you would not need a GSD at all. |
Best regards, |
