12/27/2016 11:48 AM | |
Posts: 6 Rating:
Hello my name is EFREN, I have a similar problem, i can not to connect to HMI KTP700 Basic. You can see the pictures. Help Please. ------------------------------------------------------------------------------------------ Attachmenthmi.pdf (982 Downloads) |
Last edited by: Min_Moderator at: 12/28/2016 12:01:48 AMNew subject after splitting |
1/3/2017 11:43 PM | |
Posts: 6 Rating:
Thank you. I did this operation, but nothing. The result was Not good. Do you know procedure about reset from USB? Please. Regards. |
1/5/2017 1:28 PM | |
Joined: 10/19/2005 Last visit: 11/30/2020 Posts: 1611 Rating:
Hi, what means "The result was Not good". Does it work ...did the Panel try to make the update. Be shure that you have selected the option "reset to..." and boot the Panel (look the screen in the attachment). When this does not work then you should send the Panel to the repair center. https://support.industry.siemens.com/cs/ww/en/sc/2276 |
1/6/2017 10:55 AM | |
Joined: 8/3/2009 Last visit: 4/30/2025 Posts: 15403 Rating:
Hello Efren there will be a function of resetting the Basic PAnel 2nd Generation with USB stick and Recovery Software. But today its only written in the new Version of the Manual. But the Software you need is not yet availabel at siemens so far. If the Basic Panels !!2nd Generation!! cannot start its OS then you cannot do a Reset to factory settings. You have to send it to repair center. Here is a link: https://support.industry.siemens.com/cs/ww/en/view/22639376 I know also from a few cases that contacted Siemens and support said -> Repair center Bye Murof |
1/6/2017 5:42 PM | |
Posts: 6 Rating:
Thank you very much for your support. |
5/2/2017 11:35 AM | |
Joined: 11/16/2012 Last visit: 4/27/2025 Posts: 307 Rating:
For your information: It's now possible to download the software here: https://support.industry.siemens.com/cs/ww/de/view/109744950/en?dl=en |
