6/18/2013 11:46 PM | |
Posts: 98 Rating: (6) |
As Pegaia Said, is not officially supported But it Works Great, if you configure the ports (Ethernet, COM's .. ) properly, and course "ensure you have enough memory assigned to the GuestOS." The other thing is why you want to use a VM? If you works with Win XP or Win7 there's no problem to use TIA portal. I use VM Ware 8 AsEric KVirtual Box works quite well too Best Regards
