1/6/2022 10:03 PM | |
Joined: 1/30/2018 Last visit: 7/30/2023 Posts: 2 Rating:
Hi V16 Prof installed on my computer. And Can't compile Wincc RT. I add KTP HMI or Advance PC, I can compile. But I can't compile after adding Wincc RT Professional My computer properties; 64 bit, Windows 10 Home Single Language Compile error; (software rebuild-All) ,Creation of runtime project failed. There is no access to the database CC_HMI_PNRK_22_01_06_23_38_39LT.,,,11:56:53 PM Error screen is attached. Thankyou ------------------------------------------------------------------------------------------ |
1/11/2022 1:27 PM | |
Hello Gokselkurtulus Try this: https://support.industry.siemens.com/cs/de/en/view/109780381 Bye Murof |
