8/13/2014 8:50 PM | |
Posts: 5225 Rating:
Hi there, I assume a direct link.. Try setting your PC to a fixed IP in the same range as your PLC. Autodetect can give nightmares at times. w |
8/15/2014 3:28 PM | |
Posts: 90 Rating:
Hi... If you ever find a solution to this.. please post ... I'm interested in knowing the fix too ... thanks, regards, Michael |
8/15/2014 4:27 PM | |
Try performing a repair of your portal installation. There might be a registry hack available (from Siemens HQ via Support Request), but it sounds like the new network adapter is not configured for Siemens. The repair of your portal system should install the required connections and set up proper permissions. |
science guy |
10/5/2014 8:06 PM | |
Joined: 7/14/2014 Last visit: 1/31/2023 Posts: 4 Rating:
This fix wasn't that difficult. First I unistalled all Siemens related software. Then I remove from the registry anything that had to do with Siemens and Simatic. The last step was to remove the network card from the device manager, restart and reinstall the drivers. After the reinstallation of the TIA portal the autodetection worked perfectly. I hope this fix could be useful for someone in the future.
2 thankful Users |
