9/6/2023 7:07 PM | |
Posts: 9 Rating:
Hello, I have the same query: I can get a ping to my S7-1200 PLC (192.168.10.5) when I am connected to the VPN (OpenVPN Connect), but I can't connect to the TP700 HMI (192.168.10.2). I don't know from where and how to enable the port called "HMI Load (1033)"
FYI, I have checked "Use router" and entered the router address: 192.168.10.1 and I have disabled all firewall settings on my laptop. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 09/18/2023 07:09:59New subject after splitting |
9/15/2023 10:05 AM | |
Hello Ports has to be open on PC Firewall and router Firewall if you are using. perhaps this FAQ can also help: https://support.industry.siemens.com/cs/ww/en/view/109781206 Bye Murof |
