11/5/2014 11:34 AM | |
Posts: 3 Rating:
Greetings I also have problem with UDP communication. A can't creat a ip adress in TUSEND. I created data block T_ADDR_PARAM and I tried to connect adress witch TUSEND. But I have some error. Can you tell me what i did do wrong? Best regards
------------------- New subject after splitting from broadcast messages using TUSEND from s71200. AttachmentUDP_Error.zip (81 Downloads) |
11/5/2014 2:30 PM | |
Posts: 3 Rating:
I created it in first way. And I don't know why I can't connect it with TUSEND. See the screens. I also submit my project in attachment. Best regards AttachmentUDP Error 2.zip (75 Downloads) |
11/7/2014 9:49 AM | |
Posts: 1368 Rating:
Hello I looked in your project... At Parameter ADDR, you only have to parameter "DB90"... look at attached picture. |
11/12/2014 2:38 PM | |
Posts: 3 Rating:
Ok, I can create address block. And program compile successful. But it don't work. I can't change TUSEDN REQ to 1, and I don't know why... Do you have any suggestion?
AttachmentUDP_2.zip (118 Downloads) |
