1/31/2012 9:17 AM | |
Posts: 140 Rating:
Hello Experts, I am having problem in downlaoding a program in 315T-2DP CPU PLC. Firsltly I downloaded a program that contains SINAMICS module and it was downloaded successfuly. Then I downloaded another program which had different fucntionality and it was able to run successfully. But the problem began when I again tried downlaoding the SINAMICS program (1st program). I was not able to download that program. It gave me errors which you can see in the attached document. Please go through the document and let me know your suggestions. Please ask for more information if you require so. I have tried resetting the PLC as well but still receive the same error. Thanks!
AttachmentMicrosoft Word - Can't Download Program.pdf (23 Downloads) |
1/31/2012 9:23 AM | |
Posts: 140 Rating:
Attached is the error log file along with the screenshots.
AttachmentMicrosoft Word - Can't Download Program.pdf (20 Downloads) |
1/31/2012 10:27 AM | |
Posts: 140 Rating:
I did try to change the station name by just right clicking it and renamed it. But that didn't work for me. I will try your method. |
