5/4/2011 9:19 AM | |
Posts: 376 Rating:
Hello luciferC4, Please look in the following FAQ with the Entry-ID: 40295. Link: http://support.automation.siemens.com/WW/view/en/40295 Title: Differences between the normal mode and test mode at CPU 102. In this list is described that you use the CPU102 in the Normal mode, you can not make Program changes. It is not possible. In the Test mode it shall work. Perhaps you have the possibility of trying this. With this Link you find the manual “S5-100U Programmable Controller”. Link: http://support.automation.siemens.com/WW/view/en/1091978 In the chapter 4 on page 4-6 you find information about the Test Mode. Unfortunately, I do not have any CPU102, otherwise I could have tried this. Good luck! Best Regards Gucci |
