6/4/2020 9:40 AM | |
Joined: 1/13/2014 Last visit: 9/14/2023 Posts: 4 Rating:
Hi experts, my problem is related to an IPC 427D, after upgrade from CPU 1507SF V2.1 to V20.8 I cant power on the PLC anymore, originally I was working with windows embedded 7 32bit (my original bundle with WinAC RTX F 2010, later upgraded to CPU 1507S F V2.1 all fine), then I tried doing a clean installation on windows 7 ultimate 64bit, but with the same result, trying to switch on PLC from its panel shows restart PC or terminate CPU, none of the options can fix the problem thanks in advance ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 06/04/2020 13:47:59New subject after splitting |
6/4/2020 3:52 PM | |
Joined: 7/7/2010 Last visit: 9/29/2023 Posts: 13751 Rating:
Did you load the display firmware with the latest compatible firmware for the CPU/PLC?
science guy |
6/10/2020 10:15 PM | |
Joined: 7/3/2014 Last visit: 9/15/2023 Posts: 18 Rating:
Where did you install the SW Controller? Could you show me "Disk management" screen? |
