2/25/2021 11:46 AM | |
Joined: 2/6/2015 Last visit: 4/24/2025 Posts: 80 Rating:
Hi cianoid-123, It isn't neccesary transfer the project to the WinCC Client. When you transfer to WinCC Server the configuration of the WinCC clients is also loaded to WinCC Server. Look at this FAQ: Plant Configuration Using WinCC Runtime Professional https://support.industry.siemens.com/cs/es/es/view/87054082/en Look from page 29 |
3/2/2021 8:17 AM | |
Joined: 3/11/2019 Last visit: 12/22/2022 Posts: 13 Rating:
Thank you! This is helped me |
