9/25/2013 12:25 PM | |
Posts: 3609 Rating:
Import of a Technical Question of the User Muthu R
9/25/2013 4:34 PM | |
Joined: 10/10/2005 Last visit: 11/27/2023 Posts: 1916 Rating:
Hello, the CPU in your hardware configuration of STEP 7 (TIA Portal) V12 should have the same firmware version as the real CPU with the V10.5 program. It should be V1. Change the firmware if neccessery by STEP 7 V12, save and compile and try again the upload. There are some FAQs in the internet and it could be meanful for you: http://support.automation.siemens.com/WW/view/de/66027369 http://support.automation.siemens.com/WW/view/de/41885693 With best regards |
