2/3/2020 9:16 PM | |
Joined: 2/23/2016 Last visit: 2/25/2025 Posts: 36 Rating:
Hallo every one I have a question for mp277. Can I use TIA V15 OR 14 for programing of Mp277 panel? I Don't Find Mp277 in TIA V14&15 How can program the MP277 with TIA PORTAL? ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 02/04/2020 08:20:56New subject after splitting |
2/7/2020 3:21 PM | |
Hello You can read this also in the Sales Releases for example here: https://support.industry.siemens.com/cs/de/en/view/109753803 -------------------------- Device supportChanged device support The following HMI devices are no longer supported as of TIA Portal V15:
Furthermore, HMI devices (Basic Panels, Comfort Panels and Mobile Panels) that are configured with device version V11.x are no longer supported as of TIA Portal V15. To continue using projects that contain HMI devices with V11.x in TIA Portal V15, change the device version of the respective device to at least V12.x before opening the project. ------------------------- Bye Murof |
