5/11/2010 10:59 PM | |
Joined: 7/2/2008 Last visit: 9/30/2024 Posts: 928 Rating: (309)
Hello Maha, Quite unlucky you are. Few things to add that will not contradict with what UMENCHOhad said but you can read the following if you like to increase your knowledge. The CP 443-1EX20 can be a direct replacement for CP443-1EX11 without changing the hardware configuration for H-CPUs that have firmware version 4.0 or newer. That's what you can read in page B-34 in CP443-1EX20 manualand in the following FAQ, What should you watch out for when changing from previous modules to the successor module CP443-1 (6GK7 443-1EX20-0XE0) or CP443-1 Advanced (6GK7 443-1GX20-0XE0)? Now, back to your CPU you will find that it's LITTLE BIT OLD and the latest firmware version available for this CPU is V3.1.5and here we come to the STOP. Best regards. H-H |
