10/26/2023 7:14 PM | |
Joined: 3/7/2023 Last visit: 12/5/2024 Posts: 17 Rating:
Thanks for your support.We are replacing the Existing S5 High speed counter module 6ES5 385-8MB11 25/500KHZ.instead of this module we are using the ET 200SP, TM Posinput 1 6ES7138-6BA01-0BA0 . Because this pulses are fast . Can we use the inbuilt HSC for this same here you can find the wiring of encoder. Pin5- Ground Pin8-Supply voltage (24V) pin13-Rectang-wave signal A(24V) Pin14-Rectang-wave signal B(24V) Can we use this for the inbuilt HSC instead of using TM PoS input module . ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 10/27/2023 08:40:21New subject after splitting |
