5/25/2009 7:02 AM | |
Joined: 3/21/2006 Last visit: 1/14/2025 Posts: 10239 Rating: (1182) |
Hi Rusli, Is this a new CP or old one? Did you sure about connection cable? Regards Hristo Mihalev |
5/25/2009 10:18 AM | |
Posts: 43 Rating: (0) |
Hi rusli saja |
5/25/2009 12:57 PM | |
hi rusli saja you can go to the Accessible nodes to see your PLC and to know its IP address and you must found it in the same subnet address regards |
6/5/2009 11:29 AM | |
Posts: 2 Rating: (0) |
Update for Rusli saja do you ever check to configure the CPU and the Ethernet card only? if it's still problem, maybe your ethernet card is defect. |
