2/8/2012 10:17 AM | |
Posts: 3037 Rating:
Hello, Can you make a screenshot of this error message? Does the error message appear at all projects? Which version of WinCC V11 do you use? The newest version is WinCC V11 SP2. You can delete the folder "IM" in your project folder. Now you generate the project new. Have you WinCC V11 and WinCC V7 on the same computer? You should see the following link " which sofware of simatic work fine with WinCC V11". With what is SIMATIC WinCC V11 compatible? Tweety |
2/9/2012 1:21 PM | |
Posts: 3037 Rating:
Hello, You see in the other folders under "General" if you find a place which is marked red. Can you find this place? If you do not find a place which marked red, then you can contact the customer support for behaviour. ----> customer support Tweety |
5/17/2012 3:33 PM | |
Posts: 54 Rating:
Hello, Same problem onmy pc. switch off AV mean? thanks |
