10/19/2017 9:32 AM | |
Joined: 8/3/2009 Last visit: 2/12/2025 Posts: 14745 Rating:
Hello Diakataro First look in the Panel which Firmwareversion you have (heading of the Runtimeloader Window). Check if you have the same Version in your Project. (for example 14.0.1.0 in Project and V14.1.0.X in Panel). If not then do a OS Update first. Then check this FAQ: https://support.industry.siemens.com/cs/ww/en/view/88633853 Bye Murof |
Last edited by: Murof at: 10/19/2017 9:33:10 AMIf this Information really helps, you could use the Rate function |
