7/20/2018 4:58 PM | |
Joined: 8/3/2009 Last visit: 4/25/2025 Posts: 15355 Rating:
Hello this sounds like you use Internal Tags... is it right? It exists a Safety Functoin that if you change an internal Tag with a Script or System Function then the Value change event is not executed. Its to prevent Endless loops. -> Use a PLC Tag for the Test and do it Again. https://support.industry.siemens.com/cs/de/en/view/57132412 Trick N0.1 Bye Murof |
8/2/2018 4:44 PM | |
Joined: 11/20/2017 Last visit: 4/22/2025 Posts: 7 Rating:
Yes, I am using internal tags and a System Function to change them. It makes sense, then. Ricardo Moreira |
