5/12/2022 10:57 AM | |
Joined: 3/17/2018 Last visit: 1/26/2023 Posts: 5 Rating:
Hi. I can get a S7 1215 running as NTP server. The link was helpful, thank you. I tested the NTP server functionality with the following command: w32tm /stripchart /computer:domainnameORipaddress /dataonly /samples:5 The server seems to be running as expected. But I still cannot synchronise a Unified Comfort Panel with the server. NTP server configuration at the panel should be correct. Read interval is 10 s. Any ideas why sync still does not work? System: TIA V17 Upd3 Win11 pro Latest firmware on the panel ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 05/12/2022 13:34:33New subject after splitting |
5/12/2022 4:12 PM | |
Joined: 6/26/2008 Last visit: 2/1/2023 Posts: 205 Rating:
Okay, thank you for your respons. Unfortunally I have no idea. |
