2/6/2013 2:05 PM | |
Posts: 3037 Rating:
Hello, Perhaps, the STEP 7 integration does not work correct. You deinstall the option STEP 7 integration of WinCC flexible. Then you install the option again. Or you copy your WinCC flexible project from your STEP 7 project. Now you delete your WinCC flexible project in your STEP 7 project. Then you integrate your WinCC flexible project in your STEP 7 project again. How do you integrate a WinCC flexible project in STEP 7? Copying HMI projects integrated in SIMATIC STEP 7 at file level Tweety |
2/21/2013 5:52 AM | |
Posts: 8 Rating:
Looks like the project lost the integration to Step7. Try copy and put up connections again in the Step7 project. |
