8/13/2009 6:54 AM | |
Joined: 10/7/2005 Last visit: 9/26/2023 Posts: 2988 Rating:
Hello Swright, ET200S failsfe solutions can be up to SIL3/CAT4 rated and IM151-1 HF, PM-E and F-DI,F-DQ combination is a commonly usedconfigfor this (but of course only one apsect of the whole system). Have a look at the manuals below, which should have all the info you were looking for: SIMATIC ET 200S Distributed I/O System - Fail-Safe Modules SIMATIC Industrial Software Safety Engineering in SIMATIC S7 S7 Distributed Safety - configuring and programming I hope this helps |
Cheers |
8/13/2009 9:13 AM | |
Posts: 139 Rating:
Here is another great FAQ link to heaps of info on ET200s And once you have finished reading all the material (in particular the material refered to by Fritz) use the station configurator also contained in the below link to confirm your cat3/4 design of your ET200s station. http://support.automation.siemens.com/WW/view/en/32467279 |
