12/2/2020 11:25 AM | |
Joined: 5/16/2014 Last visit: 9/12/2022 Posts: 7298 Rating:
Hello Estriga, you can use Simtic Logon for the central usermanagement see Delivery Release: SIMATIC Logon V1.6 https://support.industry.siemens.com/cs/ww/en/view/109749167 for using it with Panels, you need additional licenses on the Product Order Number
https://support.industry.siemens.com/cs/ww/en/view/109748663/98987598347 Regards Georg Berghof |
Last edited by: bg2492 at: 12/02/2020 11:25:52PS: If this post did really help you, you may use the Rate-button |
12/2/2020 3:07 PM | |
Joined: 6/19/2019 Last visit: 8/19/2024 Posts: 22 Rating:
Are you sure the passwords are not saved? By reading this I tought they would be: https://support.industry.siemens.com/cs/ec/en/view/109764540/103442715787 So, I was thinking about creating a virtual PC in the same network, then, export the users and passwords to that PC (using the function ExportImportUserAdministration) and then, import back to all the other panels and pray it would work. However, that seems a way too simple solution. I will give it a try anyway... I hope i was clear enough. Thank you for your time. Best Regards, Estriga. |
Last edited by: Estriga at: 12/02/2020 15:08:17Last edited by: Estriga at: 12/02/2020 15:08:41Last edited by: Jen_Moderator at: 12/03/2020 11:51:22Optimized link. Last edited by: Estriga at: 12/03/2020 12:26:01 |
