11/11/2024 12:35 PM | |
Joined: 8/3/2009 Last visit: 2/12/2025 Posts: 14730 Rating:
Hello MindFlayer It works on my V19 Upd3 WinCC Unified System. In Runtime it works and in Simulation of the same project it works also. If you have changed the certificate in your CA for the Webserver then you have to rerun the Unified configuration with the new certificate also. If the certificate has the same name you shoudl first delete it in IIS Server certificates. you can also delete all and start from begining: https://support.industry.siemens.com/cs/de/en/view/109806850 Bye Murof |
