9/20/2011 4:26 AM | |
Joined: 5/12/2006 Last visit: 10/9/2024 Posts: 22405 Rating: (3017)
Hello, show this threads: /tf/WW/en/Posts/61288 /tf/WW/en/Posts/60707#top 1.) you need a Siemens CF Card for SINAMICS (SIMOTION CF Cards don't work) 3.) no you can't communicate, the CU needs the FW on CF to boot up Regards Christoph |
9/20/2011 8:26 PM | |
Posts: 8 Rating: (0) |
Ok, thanks god. The complete motor's name is 1FT7108-5WF70-3BA1 Thank You again. |
9/21/2011 6:00 AM | |
There is a PDF catalog on the net for choosing cf card, it said: CompactFlash card for CU310 DP,CU310 PN, CU320 Control Unitswith current firmware version includingcertificate of license 1) without performance expansion 6SL3054-0AA00-1AA0 2) with performance expansion 1 firmwareoption6SL3054-0AA01-1AA0 3) Firmware license: Performance expansion 1 firmware optionfor CompactFlash card including certificateof license 6SL3074-0AA01-0AA0 It said that the first item is CF cards with latestfirmware version and it's includingcertificate of license so if we choose this item do we need the third item (Firmware license) ? Therefor the follwing CF card will work us: http://www.plchardware.com/Products/92/5406698/5406700/SM-6SL3054-0AA00-1AA0.aspx(although I know we should change the order number for firmware version 2.6) Also we have TM31 in our parts list, should I choose CF card with performance expansion to communicate with it? -------------------------------------- Best Regard M.Mansourian |
Last edited by: mehdihossein at: 9/21/2011 6:11 AMLast edited by: mehdihossein at: 9/21/2011 6:04 AM |
