7/24/2012 1:48 PM | |
Posts: 1 Rating: (0) |
I HAVE THE CPU 314IFM (314-5AE03-0AV0). THIS CPUΗΑS NOT MEMORY CARD. WHAT TO CPU CAN REPLACE? IF YOU CAN PLEASE TELL ME TO SOLVE A PROBLEM THAT I HAVE. THANK YOU
7/24/2012 2:36 PM | |
Joined: 9/27/2006 Last visit: 9/10/2024 Posts: 12282 Rating: (2683)
Hello Jim; The CPu 314IFM was part of the first S7-300 CPus to integrate digital and analog I/Os and technological functions (counting, positionning...). If you want he same functionnalities in your replacementPLCyou could look at the newer compact CPUs, such as the CPU 314C-PTP or CPU 314C-2DP (if you need networking capabilities). You can find the technical specifications for all the compact CPUs in the following manual: SIMATIC S7-300 CPU 31xC and CPU 31x: Technical specifications You will also find the description of the technological functions available in the S7-31xC CPUs here: SIMATIC S7-300 CPU 31xC Technological Functions Hope this helps, Daniel Chartier |
