4/2/2025 8:57 AM | |
Joined: 8/26/2024 Last visit: 4/17/2025 Posts: 1 Rating:
i wants to change POPUP window header name for each equipment with out VB script, How it possible ? ------------------------------------------------------------------------------------------ |
Last edited by: Moderator_Lan at: 04/02/2025 09:23:42New subject after splitting |
4/3/2025 8:50 AM | |
Joined: 7/27/2023 Last visit: 4/15/2025 Posts: 131 Rating:
Hi! You can assign a name in the call. If you want to modify it in the RT you should do it with JavaScripting. |
4/9/2025 11:09 AM | |
Joined: 8/3/2009 Last visit: 4/23/2025 Posts: 15338 Rating:
Hello AutoGen_8626868 which HMI do you use exactly? You are talking about VB Script and WinCC Unified do not support VB Script (only Javascript). If you use not WinCC Unified then we need to know what you are using exactly and a few more information about your usecase. Thank you and bye Murof |
