8/2/2024 9:17 AM | |
Hello AutoGen_7466618 It is possible to set the screen that is shown in a screen windows by script or with Tagvalue. In your script you do not read out the tags. you should have to use something like this: ... = Tags("Tagname").Read(); there are very good tips in this basic FAQ: https://support.industry.siemens.com/cs/de/en/view/109758536 Bye Murof |
