7/1/2010 3:24 PM | |
Posts: 6 Rating:
How can I change system time of S7 1200 from format 12 hour 3:22:00 AM to format 24 hour 15:22:00. |
5/23/2012 6:08 PM | |
Posts: 267 Rating:
Hello, I wonder that your CPU-time isn't storedafter apower shut down. Normally you haven't set the DTL to retain because it will actualize every scan time. Please check if it is the same with this sample: http://support.automation.siemens.com/WW/view/en/39182145 If you want the 24h-format, you can use the german language setting ortake the time out of the DTL stucture: hour:minute:seconds. |
5/24/2012 12:59 PM | |
Posts: 10 Rating:
Hi Regarding the M0.0 bit, i understood what it was right after i wrote my post, but many thanks About the system time, all is working now.. All i needed to do was to delete one "MOVE" function i had where it didn't belong, so now it's all working. THANK YOU so much for your time and help! |
10/27/2015 11:33 AM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4766 Rating:
New question published by mr.adi is split to a separate thread with the subject Change system time of s7 300. Best regards |
