5/29/2013 8:50 AM | |
Joined: 3/24/2009 Last visit: 6/20/2023 Posts: 535 Rating:
Dear SB1986M, The auto-creation of tags can't be disabled., but you can change adresses of a tag in the "PLC tags" -> (Your / Default)Tag table. If you open the cross-reference-list in the info-area, you can see, whether a tag is used or not. I'd suggest to define the tags (with meaningful names) before your write the code (habe a look at this thread). If you want to rewire the adresses later, the tag-table is very useful. Hope this helps. Best regards, yy1 |
