5/17/2006 9:43 AM | |
Joined: 9/27/2005 Last visit: 11/27/2007 Posts: 1398 Rating:
The quickest way would be to write a VBA function. There are examples in the manual on how to change a trigger whichare quite simple. However your function will need to be fairly sophisticated and recognise things like multiple tags in Dynamic Dialogs, multiple tag triggers, etc. I have attached a very basic example. Please note that this will need some modifications to correctly update all triggers for VBS/C, tags and dynamic dialog scripts. However it should be enough to get you started. Finally, please please make sure you have a backup of your PDL before running VBA code against it ! Attachmentchanging triggers.zip (392 Downloads) |
11/9/2016 10:38 AM | |
Posts: 13 Rating:
Hi Salma, That looks good, however can you give an example to change the trigger for a VBScript? Kind Regards |
11/9/2016 11:26 AM | |
Posts: 13 Rating:
Already made it, thanks for your help anyway! Really helped me out, now I can add tags with the specific object name. |
