8/31/2010 2:50 PM | |
Joined: 6/29/2010 Last visit: 10/27/2022 Posts: 112 Rating:
Follows an example of program tochange an analog output value pressing F button of TD
Attachmentexample.zip (275 Downloads) |
8/31/2010 9:37 PM | |
Joined: 3/4/2009 Last visit: 10/28/2020 Posts: 57 Rating:
Hi MrPaiva. I have a suggestion for your program. The first time you press F1, analog output's value will increase. Next time you press F1 analog output's value will decrease. Have a look at the attachment. The next improvement would be to make 2 speeds for value change. Short press-->low speed Long press-->hi speed Attachmentexample.zip (238 Downloads) |
Last edited by: miltos at: 8/31/2010 10:07 PMLast edited by: miltos at: 8/31/2010 10:01 PMAttachment edit Last edited by: miltos at: 8/31/2010 9:46 PMAttachment upload Rnf:lblSmileyTooltip_ (sorry Umencho) |
2 thankful Users |
8/31/2010 9:41 PM | |
Joined: 3/21/2006 Last visit: 12/4/2023 Posts: 10222 Rating:
9/2/2010 8:10 PM | |
Joined: 1/5/2007 Last visit: 4/7/2023 Posts: 1690 Rating:
Hi, i am not so happy about your solutions. Please look my answer at Manually Changing Analog Output Value with cursor keys; File: DEMO_TasterEingabe_eines_Wertes_aus_einem_Bereich.zip It contains a flexible solution to input values at a defined range with defined steps (scaling is possible). The timing of the key input can be set... Best regards Perhaps helpful links: |
==> Meine TAG-Listen: "deut." |
