4/3/2009 4:04 PM | |
Joined: 9/27/2007 Last visit: 12/18/2020 Posts: 993 Rating: (102)
Hi I did not understand what you want to do.
You has a structure with 3 different datatyps and you want to display this tags in 3 textboxes, right? You shoud use IOFields to display tags.
What do you mean with offset? What offset do you mean? Why you want to change the offset? Create a stucture in the "tag management", so you can work with the elements of the structure. With the "Event" "Focus Change" you can run a script, allot new tags to the IOFields, if you have more then one structure. regards cumulus |
Learn more about visualization - visit the HMI courses of Siemens AG! |
