11/20/2013 9:23 AM | |
Posts: 1299 Rating:
Hello, do you use runtime professional or advanced for the pc application? K!ke |
11/20/2013 9:26 AM | |
Posts: 39 Rating:
Hello runtime professional. Thanks |
11/20/2013 4:05 PM | |
Posts: 1299 Rating:
Hello, in manual there is some information about diagnosis of connections. K!ke |
11/20/2013 8:18 PM | |
Joined: 9/16/2009 Last visit: 8/13/2020 Posts: 89 Rating:
Hi you can do this lake that: In HMI Connectionmark options Coordination, and chose DB1 block In PLCdefine DB1 block. Inthis DB1 definetag Life as Word. In this DB is life bit. https://www.automation.siemens.com/mdm/default.aspx You can usethis to continuouscheck connection between HMI and PLC Best Regards Zefir |
11/21/2013 9:21 AM | |
Posts: 39 Rating:
Thanks all! |
