9/2/2014 10:16 PM | |
Posts: 784 Rating:
------------------------------------------------------------------------------------------------- Perhaps this link might help. |
9/3/2014 3:59 PM | |
Posts: 19 Rating:
Hello,
Wago, thanks for the link, it helps a lot!
dan.v., thanks for your reply, you understood correctly! About the first question, I've already tried this, but when I click the button it only shows a pop-up saying "No operator authorization" with a Ok button (Check attachement for a ps) About the second one, I checked it several times, but I don't have it, don't know why. (Check attachment) Any suggestion? Thanks again!
AttachmentScreens.zip (372 Downloads) |
9/3/2014 4:47 PM | |
Joined: 7/1/2014 Last visit: 7/10/2023 Posts: 230 Rating:
dan.v., thanks for your reply, you understood correctly! About the first question, I've already tried this, but when I click the button it only shows a pop-up saying "No operator authorization" with a Ok button (Check attachement for a ps) About the second one, I checked it several times, but I don't have it, don't know why. (Check attachment) Any suggestion? Thanks again! About the password: did you checked the "allow operator control" in the security section? Do you have that message during the editing of the panel in TIA portal or during the simulation/testing of the panel? About the schedule task: it's strange because i have different things appearing in my tia portal, maybe different updated version installed? Here is the last update for tia portal v13:Tia portal V13Update4 Sometimes updating with these patches solves a lot of problems! |
Last edited by: dan.v. at: 9/3/2014 4:52 PMLast edited by: dan.v. at: 9/3/2014 4:49 PMLast edited by: dan.v. at: 9/3/2014 4:48 PMLast edited by: dan.v. at: 9/3/2014 4:48 PM |
9/3/2014 9:37 PM | |
Posts: 19 Rating:
Yes, this option is checked in security section. This message is showing only during the simulation/testing. I've installed the Update3, forget to check for a new one! I'll install it and let you know if it solved the issue. Thanks for the link!
9/4/2014 9:09 AM | |
Posts: 1299 Rating:
Hello, I think the problem is not the update, but you're talking about different systems. Igfalco is using a runtime professional system whereas dan.v is talking about a panel. With Runtime Professional you don't have this trigger in scheduled tasks, but you have a system tag "@CurrentUser". you can use the trigger "Tag trigger" in scheduled tasks and add this tag. You can solve the other issuewith c-scripting: https://www.automation.siemens.com/mdm/default.aspx?DocVersionId=63974837515&TopicId=36122608651 But I think you will get both dialoguesif you do it this way. K!ke |
9/4/2014 6:51 PM | |
Posts: 19 Rating:
Thanks for your reply, K!ke! Possibly we were talking about different systems as dan.v got different options in the trigger list. I think using the @CurrentUser tag will do the trick! About the other issue, I'll try it using c-script, thanks for the tip!
