12/6/2012 12:41 PM | |
Joined: 4/22/2010 Last visit: 12/13/2024 Posts: 5697 Rating: (715)
Hello, Yes you can use this module with RTD, attached you find all the information about this module. The temperature is measured in 1/10 th of a degree, i.e 22,5 degrees is read by plc 225. to display the real temperature you convert to real first and then devide by 10.0. To switch heating you can use the compare real function. Regards, Marcjan Attachment1KF02 analog module.pdf (520 Downloads) |
Problem solved? |
