11/23/2012 4:30 PM | |
Posts: 3037 Rating:
Hello Vladymyr, https://www.automation.siemens.com/mdm/default.aspx?DocVersionId=41583856907&Language=en-US&TopicId=21477948811 Can you see your Server and your Client in the SIMATIC Shell? https://www.automation.siemens.com/mdm/default.aspx?DocVersionId=41583856907&Language=en-US&TopicId=26784035083 Tweety |
11/26/2012 12:54 PM | |
Posts: 3037 Rating:
Hello, Do you use a Server client system and a OPC Server? Can you explain your system? Do you check your configuration with this link? Tweety |
11/27/2012 1:18 PM | |
Posts: 3037 Rating:
Hello, You need only following groups: "Power user" rights and " SIMATIC HMI" for WinCC Professional V11. See the link point 5 under WinCC V7.0 SP2 Upd 1 What should you watch out for when downloading from the WinCC/PCS 7 Engineering Station to the Operator Station (ES-OS download)? Tweety |
