12/21/2011 3:32 PM | |
Joined: 5/28/2008 Last visit: 3/21/2025 Posts: 1343 Rating:
Have you done the Hardware Configuration of your PLC and CM1241? There you can adjust general settings like baudrate and so on. Fpr receiving data you have to you use "RCV_PTP" Block. Maybe have a look to this application to get a little bit more familar with the process: Flexible Decoding and Processing of Data Matrix Codes with S7-1200 (CE-X27) |
12/22/2011 1:53 PM | |
Posts: 59 Rating:
To send a message do you need only the SEND_PTP or is necessary other function? |
11/19/2012 1:42 PM | |
Posts: 11 Rating:
hELLO, i AM CURRENTLY HAVING THE SAME PROBLEM . pLEASE, HOW DID YOU GO ABOUT THIS? |
11/19/2012 8:21 PM | |
Joined: 4/22/2010 Last visit: 2/26/2025 Posts: 5697 Rating:
Hello, Maybe this thread is of any help: S7-1200 RS232 regards, Marcjan |
Problem solved? |
