11/14/2014 8:51 AM | |
Posts: 3 Rating:
Hi, I don't know if this is the correct forum to post my request but hopefully you guys can help. I have 6ES7241-1CH32-0XB0 CM 1241 RS422/485 module. I am having an issue when the plc is restarted that the module does not seem to transmit any values. Only once i cycle the plc (stop >> run) does it start working. Then everything is fine unitl you restart again. Any ideas ? Im using a WTB485 weighing module and transmitascii. To add some more information, i have replaced themodule to confirm that its not hardware. Also the previous machine was built with6ES7241-1CH31-0XB0 and this problem did not occur on that module. thanks in advance |
Last edited by: Alex.maritz at: 11/17/2014 7:48 AMLast edited by: Min_Moderator at: 11/14/2014 12:50 PMsplitted Last edited by: Alex.maritz at: 11/14/2014 8:52 AMLast edited by: Alex.maritz at: 11/14/2014 8:51 AMLast edited by: Alex.maritz at: 11/14/2014 8:51 AM |
11/18/2014 11:54 AM | |
Joined: 3/20/2013 Last visit: 3/27/2025 Posts: 676 Rating:
heyhey, thanks for the feedback and good luck |
Best Regards, |
6/17/2016 9:54 AM | |
Joined: 8/21/2014 Last visit: 3/26/2025 Posts: 1035 Rating:
New question published by GaJEnDrA D S is split to a separate thread with the subject CM 1241 RS422/485 randomly stops sending data. Best regards |
