3/16/2016 5:32 PM | |
Posts: 11 Rating:
Hello, I try to communicate a loop detector LD4-B whit a module CM1241 in the RS 485 freeport. But the module can´t detect the signal from the LD4 card. I use point to point communication in the TIA PORTAL software. I will apreciate your help. Thanks. ------------------------------------------------------------------------------------------ |
Last edited by: Min_Moderator at: 3/17/2016 1:37:28 PMNew subject after splitting |
4/11/2016 4:03 PM | |
Posts: 11 Rating:
These are blocks of the program in TIA PORTAL. |
4/19/2016 3:03 PM | |
Posts: 11 Rating:
The card is for traffic count. The characteristics of this is card attached.
AttachmentLD4-Produktblatt-gb.pdf (51 Downloads) |
