7/20/2021 11:23 AM | |
Hello kcanoglu Which PLC do you have, it works only with S71200/1500: https://support.industry.siemens.com/cs/de/en/view/49313233/118959352843 Which Image do you use on the Panel? do you have the latest update in your TIA V16 and the latest Panel images update? then you should be able to use the V16.0.0.5 Update Try wth this Bye Murof |
