8/26/2011 9:52 AM | |
Posts: 947 Rating:
Hi Jason Unique Name you can use Primary Setup Tool. This programm has command string interface, command you can send from own programm. in depends your network hardware you must use appropriate version utility. this utility is freeware |
8/26/2011 9:29 PM | |
Posts: 6 Rating:
Rated X and gre_m, Thanks for the responses. I am going to try the Primary Setup Tool and I will post back how that works. Thanks again, Jason |
10/31/2011 3:17 PM | |
Posts: 6 Rating:
Hello, I forgot to post back to this thread. The tool worked really well. Thanks for the help, Jason |
