2/2/2012 1:17 PM | |
Joined: 3/21/2006 Last visit: 3/14/2025 Posts: 10239 Rating:
Take a look at Communication between IM 151-8 and CPU 315-2 PN/DP over Ethernet/Profinet., specially at our expert fritz's post. Best regards, Hristo Mihalev |
2/2/2012 2:12 PM | |
Joined: 8/31/2010 Last visit: 2/8/2025 Posts: 1524 Rating:
SIMATIC NET COLLECTION- Check this space which has many samples in it. FYR |
Like it? Rate it! |
2/3/2012 6:42 AM | |
Posts: 303 Rating:
Thank You. i visited this link based on your reference https://www.automation.siemens.com/net-static/Quickstart2009/quickstart012003/html_76/ethernet/ie_tcp_s7_s7_s7.htmbut i am unable to find solution for my problem. can you please help me out.
2/3/2012 7:06 AM | |
That collection has examples for Communication Processor modules. Still for CPU - CPU communication you can refer this - CPU-CPU communication with SIMATIC controllers (compendium) |
Like it? Rate it! |
2/3/2012 7:13 AM | |
Hello Avinash, How do you program communication blocks FB14 "GET" and FB15 "PUT" for data exchange in the S7 program of an S7-300 CPU? which is applicable for ET200S IM151-8 also. In the above sample, it is configured for CP in S7-300, in your case it is going to be IM151-8 CPU (making use of onboard ethernet interface) |
Like it? Rate it! |
2/3/2012 1:55 PM | |
Posts: 303 Rating:
Hi Ganes10. i got the solution thank you |
11/6/2014 2:23 PM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4766 Rating:
