3/26/2009 8:38 AM | |
Posts: 28 Rating: (1) |
If the Mitsubishi plc can act as a master you can use a DP/DP coupler. A very easy way to communicate betweeen two master system. |
3/26/2009 2:36 PM | |
Joined: 3/21/2006 Last visit: 12/2/2024 Posts: 10229 Rating: (1181) |
Hello, Look at possibility to connect Mitsubishi PLC like profibus slave to Siemens PLC like profibus master. Some details about this type of connection, deppending of type of Mitsubishi PLC. here There isn't exactly your configuration, but you can take some points. If you give more details... Hope this will helps. Best regards |
