9/13/2018 8:24 AM | |
Posts: 5 Rating:
Hello Santosh, Thanks for your shared documents. I am trying to communicate Danfoss fc360 on RS485 using S7-1200 with cm1241. I have checked all the settings for MB_COMM_LOAD & MB_MASTER blocks. Problem is i am not getting data. TX led is flashing and also MB_MASTER Busy is flashing true/false. Please guide me what should i change in my program or settings? Regards Avnish Chauhan. ------------------------------------------------------------------------------------------ |
Last edited by: ZACK54544 at: 9/13/2018 8:24:39 AMLast edited by: Jen_Moderator at: 9/13/2018 9:09:18 AMNew subject after splitting |
9/13/2018 10:05 AM | |
Posts: 5 Rating:
Hello All, Please find the attached file. I am not getting data from the danfoss drive. With the same setting i am able to check the data on the MODSCAN software but when i am trying to read/write the data through the PLC program. It's not working. Please help me out with your suggestions. With regards Avnish Chauhan. AttachmentRS485.pdf (516 Downloads) |
9/18/2018 2:58 PM | |
Joined: 4/28/2015 Last visit: 3/26/2025 Posts: 10837 Rating:
Hello, thank you very much for infos. |
With best regards... |
