10/24/2012 9:55 AM | |
Posts: 1547 Rating:
Hello, in your configuration you use the routing functionality. First of all check if the CPU type you use will support this function. Then refer to this FAQ: How do you configure field devices with SIMATIC PDM via Industrial Ethernet? |
