6/7/2009 7:35 AM | |
Joined: 9/27/2006 Last visit: 3/24/2023 Posts: 11994 Rating:
Hello Joji; The following link will take you to an applicationexample for Profibus-DP communications between a CPU 315-2DP and a Controllogix processor equyipped with a SST scanner.: http://support.automation.siemens.com/WW/view/en/23809864 You will find code as well as documentation on the proposed solution in the download. You should be able to adapt the situation to yourselected hardware. This should be even more detailed than my previous reply, but also easier to follow. Hope this helps, Daniel Chartier |
