8/29/2017 2:54 PM | |
Joined: 9/27/2006 Last visit: 3/23/2025 Posts: 12344 Rating:
Hello sbartoc; The selection and integration of protocols for the Exor panels seems to be an attribute of the programming software, JMobile Studio. Profibus-DP (and something called Profibus DP S7) is mentionned in the following protocol list: http://www.esco-da.be/Protect/HMI%20UniOP/TechNotes/ptn0534.pdf I would suggest you contact your Exor panel provider and ask if the protocol is to be licensed, and what is required to make t run. Hope this helps, |
2 thankful Users |
8/30/2017 7:34 PM | |
Hello sbartoc; If you do not wish to purchase a CP 343-1 (possibly Lean version) for this application, you could look into this nterface module: https://www.ibhsoftec.com/IBH-Link-S7-PP-Eng Hope this helps, |
